No air in vents and a P0400 + p0336B code
Ok now I have a new set of questions. I figured it may be a vacuum leak being the reason for now a/c in the vents. But my car is also throwing a p0400 egr system code and a p0336b clp sensor circuit perf code. Could it just be the egr solenoid or something? Also is there a dye you can buy to find the vacuum leak?
Thanks in advance
Thanks in advance
info here https://camaroforums.com/forum/93-02...4th-gen-68660/ and here at number 2 on the list https://camaroforums.com/forum/93-02...62/#post557639
Ok found a broken hose.
Ok just had the engine put in and on the passenger side there are wo vacuum lines that go to the back of the engine and neither I hooked up! There is also to places on the rear of the manifold for two hoses, why is this not showing up in te diagrams?
Figured it out! The mechanic ran my hvac line to the fuel pressure thing... and just left those two on the side un-done. Ridiculous... Re-ran everything and it all works now! Thanks for the diagrams, craby!
Jelz28
07-20-2012 11:00 PM
chris.langlais
10-13-2011 01:31 PM
