LT1/LT4 Tech 1993-1997
No 1st Gear on Shifter
Old 04-11-2008, 08:37 AM
Clod_Z28's Avatar
Default RE: No 1st Gear on Shifter
It's an automatic transmission, the shifter does read OD D 3 2, but no 1. If it's a swap and it's not a 4L60E, what do you think it is?
Old 04-11-2008, 09:37 AM
SpecterGT260's Avatar
Ninja Administrator
ORIGINAL: 95slvrZ28
If you have OD, D, 3, 2 that means you have a 5 speed manual, which would have had to been swapped in because the 4L60E is a 3 speed with overdrive.
And Spec, I'm pretty sure when you hit the OD button it just shifts the car down to 3rd, which is usually it's 1:1 ratio.
maybe for the camaro. ive never owned an auto american car
but in my old carolla, the OD button raised rpm about 500 at 80mph, while actually going into 3rd was a larger jump. is there any technical data on the 60niner4LEninersomething?
Old 04-11-2008, 09:50 AM
Ninja Administrator
does ur tranny not have a 3? mine had D-3-2-L and it had an O/D on/off button.
if you go OD-D-2-L then you may be right about ur car, but if you have both D and 3 then it makes no sence
EDIT
he has a D and a 3. if D really did lock u in 3 there were some we-todd-did engineers at GM. OD and D gotta be a different main drive gear that interacts with the transmission gears, at least in his tranny and my toyota
Old 04-11-2008, 09:58 AM
Ninja Administrator
that looks to me like a 4th gen center, so ya, looks like D stands for a 3rd gear lock in this case
Old 04-11-2008, 10:39 AM
95slvrZ28's Avatar
That would be what mine looks like, and sorry about that previous post I meant to say "you have a 5 speed auto" but it's so counter intuitive for our cars...
Either way, if your center console doesn't look like that, I'm not exactly sure what happened, sounds like somebody did something and now you get to deal with it.[&:]
Old 04-11-2008, 12:22 PM
Clod_Z28's Avatar
First off I'd like to say I'm a retard because the whole time I've been saying that the shifter has OD D 3 2, and it doesn't.It has OD D 2 but it does not look like the picture above because it does not have a 1 anywhere on it. It's not really a problem, I was just wondering why I don't have the option to put my car into 1st gear without steping on the gas and letting the transmission kick down. I guess I'll have to get under the car and see if there's something stamped on the transmission that would tell me what kind it is.
Old 04-12-2008, 08:32 PM
SQ1110's Avatar
I just went through this with mine,you can take the cover off,and when you pull the shifter back all the way it hits a small rubber block,cut the rubber block off with a hacksaw blade and you'll have first gear. Good Luck.
Old 12-10-2009, 08:16 PM
taylordeuce's Avatar
Default 1st gear
the cars that came from the factory with 2.73 gears had the 1st gear lock out. the cars that came with 3.23 gears had 1st
bulldogrsp61
82-92 V8 Tech
10-24-2010 07:17 PM
DIPSTICK_JIMMY
09-24-2009 08:00 PM
250motorsportz
07-19-2008 12:03 AM
soulvoid
02-10-2008 06:00 PM
thebandit110
03-13-2007 01:54 AM
Quick Reply: No 1st Gear on Shifter
