LT1/LT4 Tech 1993-1997
neeed help now!!!! need engine
Old Feb 14, 2008 | 07:44 AM
sepadowd's Avatar
Default neeed help now!!!! need engine
for some reason i am having a hard time finding the casting numbers for the 5.7 ltr lt1 block. i have heard the last 3 numbers should be 327, is this correct i dont want to get the baby lt1. i am told the motor is out of a caprice. also is it true you can port the cast iron heads more then the aluminum ones thanks
Old Feb 17, 2008 | 10:49 AM
Pro_built7's Avatar
Default RE: neeed help now!!!! need engine
im pretty sure it is 5327 5.7, check ls1tech.com someone just posted something up about this
martynlutherking
May 25, 2010 11:12 PM
Chevykicksbut
Oct 28, 2009 07:14 AM
drabina
Jul 25, 2008 08:56 PM
irocktheIROC
Apr 8, 2008 05:42 PM
BIGS1983
82-92 V8 Tech
17
Jul 14, 2007 11:03 PM
