LT1/LT4 Tech 1993-1997
Need info!
Old Aug 19, 2012 | 11:04 PM
My93camaro's Avatar
Default Need info!
So I recently installed a 383 stroker lt1 in my 93 camaro. I got a chip from a guy in Denver, the adapter is from chips for less but the guy did the tuning himself. The car doesn't seem to run as well as it should. What is the best placd to get tuning for a 383 lt1? And what else can I do with in reason to get this car running like it should?
Old Aug 19, 2012 | 11:56 PM
MKCoconuts's Avatar
PCM for less is probably the best out there. Gotta find the link.
Here we go. http://www.pcmforless.com/
Old Aug 20, 2012 | 05:31 AM
i have had very good work from solomon at LT1 PCM Tuning - OBDI/OBDII PCM Tuning/Programming Service have tune from both pcmforless and lt1pcmtuning and she runs better with solomons tune. .
Old Aug 20, 2012 | 09:03 AM
Edwardgp's Avatar
craby lays down some good information.
Old Aug 20, 2012 | 12:29 PM
MKCoconuts's Avatar
Jeeze, I almost forgot about Solomon! My minds just in too many places right now.
Old Aug 22, 2012 | 11:02 PM
My93camaro's Avatar
alright thanks. Also I am running pretty much stock everything else, except tranny. Do I need to upgrade my injectors or anything??
Old Aug 22, 2012 | 11:49 PM
no dont need to. would be a good time to invest in some upgrades if you can afford it. headers, exhaust, cai. are the heads stock?
Old Aug 23, 2012 | 10:05 PM
My93camaro's Avatar
The valves and everything in the heads are upgraded. Have slp loudmouth exhaust and cai. Just looking for a little better performance. Has old fuel in the car though, mixed with newer fuel. That could possibly be part of the problem.
Old Aug 23, 2012 | 10:29 PM
drain the tank and use the gas in your mower. for piece of mind if nothing else. tune will do you good, good tuner will need to know all the particulars on any upgrades to do the tune right.
RodneysPhoto
Mar 28, 2011 01:44 PM
camarogurl843
82-92 V6 Tech
Nov 4, 2010 02:44 PM
Skidoo03
Oct 18, 2010 06:39 PM
Homestar1217
Jun 27, 2009 08:37 PM
vinnyboombots
Apr 4, 2009 03:14 AM
