LT1/LT4 Tech 1993-1997
need help asap on overheating
Old Aug 16, 2006 | 07:12 PM
yellowjacket01's Avatar
Default need help asap on overheating
its on a 97 z28 with 135,ooo miles. The car will get to about 240 or the quarter mark away from red,sitting in traffic it does this and it seems the only way it will go back to around 210 is give it gas,i need help with this as soon as possible.
Old Aug 16, 2006 | 08:02 PM
1971 Z28's Avatar
Default RE: need help asap on overheating
What kind of radiator are you running? Do you have electric fans? Has it always run that hot or is it a recent thing? If it is recent then what did it used to run before it began running hot?
Old Aug 16, 2006 | 10:18 PM
Step 1)
In the driveway, turn on the AC & note if fans come on within a few minutes.
If fans do not come on, there is a problem in the fan ciruitry or the fan motor itself.
If fans come on, the fab motors and fan circuitry is good,
Step 2) Do this if the fans came on on step 1
In the driveway, let engine idle until hot. The fans should come on at slow speed and bring temp down.
if fans do not come on, there is propaply a problem with the coolant temp sensor (not the temp gauge sender) or the wiring assocaiated with it.
Old Aug 17, 2006 | 11:45 AM
thanks i appreciate it, we bought this car that had been sitting up for a year,so just trying to get all the kinks out,the fans will come on,and will go down a little but when given gas,the car actually starts to cool.
Old Aug 17, 2006 | 01:30 PM
hardwire666's Avatar
thermostat or water pump. Thats my $.02
Old Aug 17, 2006 | 04:59 PM
Definetely, if the fans work, they should be the two next things to look at. Also check that thereis no air in the system. Open the two air release valves & run the engine until a steady stream of coolant comes out and then close them.
Old Aug 17, 2006 | 07:36 PM
ok new thermostat now it stays cool,fixed that problem,thing is it misses now,maybe horrible gas we ran 2 tanks through with some fuel treatment,were going to do the plugs next,already changed the oil new coolant,we scanned it and it was rapid random misfire,and a couple other codes that we were told would go away if the misfire could be fixed,there suggestion was wires plugs and coil,but all have been replaced along with the water pump besides the plugs,where do you think we should go next say the plugs dont fix the problem.
Old Aug 17, 2006 | 08:21 PM
Saint_Ali's Avatar
yes the plugs need to be replaced if its missing like that, its probably the reason, i changed my plugs when mine was missing after that it was fine.i dont know about the horrible gas, just make sure your using premium, you might want to put a new fuel filter in
Old Aug 17, 2006 | 11:35 PM
alright thanks for your input,ill try the plugs
Old Aug 17, 2006 | 11:39 PM
say its not the plugs and its the distributer,has anyone heard of this before? http://www.paceperformance.com/index...&ProdID=146725
