LT1/LT4 Tech 1993-1997
need help
Old Oct 6, 2021 | 01:48 PM
oldnintyseven's Avatar
Default need help
my 95 lt1 camaro has a bad stumble/misfire at low throttle positions such as driving on highway. The engine clears up if I give it more throttle. I ran two scans last week. Can anyone look at them and see if there are any clues?
File Type: csv
File Type: csv
Old Oct 7, 2021 | 12:08 PM
have you tested fuel pressure yet? also pull plugs and 02 sensors to see if they is all black an fouled.
Old Oct 7, 2021 | 12:18 PM
I assume there was no codes? The O2’s look funny but that could be caused by an ignition miss or injector problem or even a vacuum leak next I would put it on an oscilloscope. A good scan tool can count cylinder misses. but even that has it limits because it will not show a fueling issue or vacuum leak.
How old is the Opti?
Old Oct 7, 2021 | 03:16 PM
Not sure age of opti I put new regulator pump and injectors it was flooding before that I got new plugs and wires I will install them tomorrow
Old Oct 8, 2021 | 12:04 PM
Well if you had flooding issues there is a good chance your O2s are contaminate and will need replaced. We are just talking about the 2 O2s closest to the heads.
B_Dubya
Sep 23, 2014 11:01 AM
VALHAR
Sep 10, 2013 10:20 AM
red star
May 8, 2009 07:42 AM
dorn4ever
May 23, 2008 12:28 AM
blcp86
Jun 30, 2006 09:11 PM
