LT1/LT4 Tech 1993-1997
my 97 camaro consal vibrats
Old Jan 14, 2010 | 01:40 AM
franco-28's Avatar
Default my 97 camaro consal vibrats
hi I own a 1997 camaro z28 and my consal vibrats when i drive at high speeds it only started doing it after i rebuilt my transmision. can anyone help me out if they no what it is ??
its not the trany mounts cause they replaced those already twice. I brought the car back to the shop and they could not find the problem can anyone help me plz..
Old Jan 14, 2010 | 12:44 PM
what kind of trans mount did they put in. the poly mounts will transfer vibrations bad.
Old Jan 17, 2010 | 11:57 AM
greenarrow's Avatar
September 2009 ROTM
Even worse effect with poly motor mounts also.
Old Jan 18, 2010 | 04:30 AM
franco-28's Avatar
im not to sure what kind of mounts they are he never told me I put a shift kit in my automatic transmission and it staped my stock tranny mounts twice. but even when i had my stock mount since it came out of the shop with a rebult tranny it seemed a lil diffrent and started vibrating the consal
its pissing me off and i need to find how to fix it !!!
Old Jan 18, 2010 | 11:32 PM
greenarrow's Avatar
September 2009 ROTM
You could have a u joint going maybe, but I would think that would show up at slower speeds. What you're describing is exactly what mine does with the poly trans/motor mounts. It's really not that noticable any more though. I had to put some tubing around the parking brake spring to keep that from rattling. Maybe driveshaft out of tune, I wish I could help for sure.
Old Jan 19, 2010 | 12:58 AM
get under there and have a look, if its solid it poly, many are red in color. if theres a hole going through it that lets it flex then its stock. u may be able use something like this to take some of the pressure off the trans.
http://www.spohn.net/shop/1993-1997-...GM-F-Body.html
