LT1/LT4 Tech 1993-1997
mods and upgrades
Old Jul 24, 2009 | 12:51 AM
carguylt1's Avatar
Default mods and upgrades
My 95 z went down about three years ago. I have most of the parts I want to go back on it. electric water pump, cold air, off road-y, LT4 cam kit, and a set of 2.02/1.60 valves. I want to replace the opti along with the coil and maybe add an ignition box. a friend told me I may want to swap the fuel pressure regulator and injectors. I am not changing displacement or compresion just freshening up the original bottom end.
Old Jul 24, 2009 | 01:33 AM
it would be a good idea to move up to 30lb injectors, are u having the heads done ported and polished? probly want to go with a 52mm tb. 58 if u have the intake done. what kind of exhaust do u have? u will not get the full potential of the motors inprovments with out some headers, free flow cats and cat back exhaust.
Old Jul 24, 2009 | 11:24 AM
carguylt1's Avatar
I plan on p&p the heads. gasket matching the intake my self. i have a three in y no cats and a no name muffler. I will have to get the headers later. I just need the car to run rite. I am the proud daddy of 13 day old twins. I need a second vehicle now.
Old Jul 24, 2009 | 11:55 AM
95slvrZ28's Avatar
If you just want it running you won't need to swap injectors. If you're trying to make power you'll want to upgrade to 28 or 30 pound injectors. I personally don't think your cam is big enough to necessitate a new TB, not yet anyway, and for sure not to get it running...
By the way, congrats on the twins!
Old Jul 31, 2009 | 08:11 PM
carguylt1's Avatar
So even with the bigger valves I won't starve the car for fuel. I was told the TB will handle about four hundred.
Old Aug 1, 2009 | 08:56 AM
whammer3024's Avatar
ROTM Winner
stock throttle body will handle about 350rwhp(at least thats when i'd start thinking about changing things). and there's really no point in going with a 52mm TB, i'd just go with a 58 if i'm going to do it and have the intake ported at the same time.
with the hotcam kit, 30# svo injectors would be more than sufficient
redemption91
Apr 15, 2010 10:32 AM
sinfulrs
82-92 V6 Tech
Dec 27, 2009 12:48 PM
whammer3024
Jun 10, 2007 12:26 AM
Wrex Zero
Feb 23, 2007 02:40 AM
92camaro305
Aug 1, 2006 02:17 AM
