LT1/LT4 Tech 1993-1997
Missing coolant?
Old Jun 26, 2020 | 07:15 AM
  #21
dgriffi2's Avatar
Thanks. All of this started after the shop changed plugs and wires and distributor, and had water pump off so replaced gasket. I can’t help but wonder if it’s somehow related to that work they did. But when I removed the battery there was that little puddle of coolant, which led me down the path of replacing the reservoir tank... ugh.... it’s frustrating tracking down these gremlins!
Old Jun 27, 2020 | 11:59 PM
  #22
MKCoconuts's Avatar
Sucks I haven't been on here lately and didn't respond sooner. After reading your original post, my first thought was to tell you to check under the battery tray for a leak. It's pretty common on these and tricky to spot it actually leaking. Surprise Craby didn't make that suggestion right off the bat.The other suggestion I would have had was to check plugs individually and see if one is abnormally clean. That would indicate coolant being burned in the cylinder, which has a nice steam clean effect.
Just an FYI, my reservoir cap doesn't fit tight and have zero issues with pulling coolant. I've also ran into an issue where I had to constantly add coolant to the radiator after having the system open. There can still be air pockets in the system. Like Crabs said, these can be a ***** to bleed.
Old Jun 28, 2020 | 08:04 AM
  #23
dgriffi2's Avatar
Thanks. I love these forums because everyone is so helpful! My shop did a pressure test and found a hose leaking- can’t recall which one and don’t have the paperwork in front of me- it’s a long, twisted one that they said “gm likes” to the tune of $250! I’m relieved to know my overflow tank cap doesn’t have to fit perfectly- but I was thinking (uh oh) there must be a way to rethread the bottle? The caps are fine.
grasshopper645
Jan 27, 2013 03:08 PM
JakeYeah
Nov 10, 2012 05:15 PM
josh3408
Mar 8, 2011 08:00 AM
Saint_Ali
Dec 15, 2006 08:54 PM
Z28man
Oct 6, 2006 09:41 PM
