LT1/LT4 Tech 1993-1997
misfire
Old Feb 24, 2006 | 08:05 PM
leadfoot55's Avatar
Default misfire
if i havea misfire on a cylinder will my oild pressure be a little lower?
Old Feb 25, 2006 | 04:36 PM
Default RE: misfire
A misfire should not affect oil pressure unless it has been going on for a long time and dumped a lot of raw fuel into the oil and diluting it. An ongoing missfire, besides being annoying , is bad for the engine as the raw fuel washes the oil off the cylinder walls causing the rings and cylinder walls to wear out at a very fast rate. The worn out material is deposited into the oil pan and circulated about the engine causing even more damage. I suggest you find the reason for the misfire, usually an ignition or fuel injector problem, and take care of it.
samkopyna
Sep 5, 2012 10:41 AM
leonard1
Oct 23, 2011 10:41 AM
steveh3500
Feb 18, 2010 01:56 PM
dumbnstupidone
Jan 21, 2008 08:40 PM
NasteeZ
Oct 31, 2007 09:55 AM
