MAXED OUT FUEL SYSTEM
ORIGINAL: 2fast2c
My z28 is maxing out my fuel system.
I am thinking about a Aeromotive system.
I currently have 60lb injectors with two 255lph pumps..
Im running a built 383 with a procharger D-1. The injectors are not maxed out just the fuel supply. We are currently making 625RWHP at 5000RPM then we run out of fuel!!
What kind of HP can the stock lines and fuel rails support?
The injecters and pumps should be good to go. Your fuel rails and lines could be the week point. With that kind of power your probaly just under 700 crank horses and the stock lines and filter could be failing you easy.
