LT1/LT4 Tech 1993-1997
Mass Air Flow Sensor Porting
Old Apr 21, 2009 | 08:48 PM
lt4weeda's Avatar
Default Mass Air Flow Sensor Porting
I was wondering about porting out my mass air flow sensor to save my self 50 bucks from having to buy a bigger housing. I have everything I need to port it at my work. I know you can buy the bigger housing from mid america and it is a 80mm. I was wondering if anyone had an idea of how much you can take off before you are going to break through the housing. If not I guess I will just have to mess around and find out, but I just thought it would be nice to know before hand.
Old Apr 22, 2009 | 01:24 AM
95slvrZ28's Avatar
I don't think anyone around here has tried...
Have fun!
Old Apr 22, 2009 | 01:39 AM
lt4weeda's Avatar
haha well i just figured, worst thing that could happen is i ruin the housing and just buy the bigger aftermarket one so not much to lose
Old Apr 22, 2009 | 01:44 AM
jagass's Avatar
Good luck to your plans...I hope it will work...
Old Apr 22, 2009 | 02:51 AM
greenarrow's Avatar
September 2009 ROTM
Well actually I ported my stock MAF on my LT1. I used a metal hand saw and cut out the fins inside and then used a dremel to sand it all smooth and then polished the crap out of it. I've heard mixed results from several people about doing this. Some had bad problems and their car didn't run right and they ened up replacing the MAF. I didn't have any problems with mine, stuck it in and it started right up and has felt fine since. There's a couple pics on my cardomain page. I think as long as your careful with the actual sensor part then you should be fine. While you have it apart, good idea to clean it with some electronics cleaner. Just be careful around the tiny wires.
Old Apr 24, 2009 | 02:10 AM
lt4weeda's Avatar
well if i did it, I would take the sensor out of the housing obviously. I measured it and i can't take much more than 2 mm off if i leave the center fin. However if I cut the center fint out I can run it on a lathe and make it nice and smooth, but by time I get that far I could order one of the internet and have it here, but then it would be cool to say I ported my own maf haha
Old Apr 24, 2009 | 02:40 AM
greenarrow's Avatar
September 2009 ROTM
I say go for it, it probably won't take you all that long once you get started.
Old Apr 24, 2009 | 10:26 PM
lt4weeda's Avatar
well if i get the center cut out, i will just throw it in the lathe at work and then it will go by way quick. just have to figure out how i want to go aobut cutting the center fin out
mfmfim
Aug 13, 2012 06:24 PM
sergio805
May 31, 2010 08:24 PM
jml317
82-92 V8 Tech
Dec 12, 2007 02:44 PM
97rsturbocamaro
Nov 18, 2007 09:57 AM
