LT1/LT4 Tech 1993-1997
March Alternator pulley
Old Feb 18, 2013 | 06:54 PM
impalassv8's Avatar
I havent had a chance to get a volts check yet. But i believe the idea is to speed it back up to an acceptable rate in conjunction with the crank pulley.
Old Feb 18, 2013 | 08:17 PM
Yeah it is, was making sure you didn't want to slow it down even more. As far as the voltage output, you want to check with having every possible power option on.
Old Mar 24, 2013 | 12:56 AM
blaze1's Avatar
Hello fellas. Bear with me as this is my first post on any forum. I installed a BBK underdrive pulley on my 95 Camaro Z28 and naturally my alternator was not putting out enough voltage at idle. So after some searching I found that March makes an alternator pulley that will work. The March part # is 110-08. Hope this helps.
Old Mar 30, 2013 | 12:54 AM
impalassv8's Avatar
Hey thanks man, i got one ordered thru:
Hawks Third Generation › 1982-2002 Camaro and Firebird Specialists
Ours use the MCH# 121-08
http://s-seriesforum.com/albums/albu...2398.sized.jpg
The one on the left i see most of the f bodies use which probably use that 110-08. The one on the right is the style on my Impala, according to summit racing thats the part number for 93-97 Gen II LT based (MCH 121).
deez28
Oct 21, 2013 08:56 AM
nj85z28
ROTM 2013
22
Mar 8, 2013 09:12 AM
cplthomas
ROTM 2008
65
Mar 1, 2008 12:19 PM
baseballer91
Jan 24, 2008 06:21 PM
Hawk
ROTM 2007
82
Mar 2, 2007 08:56 PM
