LT1/LT4 Tech 1993-1997
Major prob. need help
Old May 4, 2010 | 11:33 AM
red star's Avatar
Default Major prob. need help
I replaced my fuel pump on my 96Z28 a few months ago. it doesnt even have 10k miles on it. my dad is driving my car from CA to LA where i live. He is in NM and it just died. he cranks just fine but wont start. he said that it sputtered then died and it wont stat now. i had this issue a few times before. first time i was going up a hill and it started to cut out so i pulled over but it was ok once i was on the side of the road. Next time it happend i was only 100 yards from home. it started a little slow then just died. it wasnt geting enough or any fuel. it started about 20 min after that. just started right up and it has not had that issue since then. i know this is very little info. but any ideas?
Old May 4, 2010 | 12:04 PM
can he hear the pump coming on when the key is first turned on? what kind of fuel pump did u use? i had a ignition module fail that did that. it would quit and 20 minutes later start right up and run fine.
Old May 4, 2010 | 03:28 PM
red star's Avatar
do you know what code that would be?
Old May 4, 2010 | 03:41 PM
if u used a cheaper pump when u replaced then i would suspect the pump. there is no code for a bad pump. have u had it scanned?
Old May 4, 2010 | 03:53 PM
red star's Avatar
i own a code reader but its back in CA so dads gatta pay 65 buck for a dude to read the code. it wasnt a cheap pump...i think. but it has a life time warranty.
Old May 4, 2010 | 08:01 PM
i guess a good first step would be to check all the fuses in both fuse boxes. one under hood and one in car. especially the ignition fuse and the injector fuses.
Old May 6, 2010 | 03:50 PM
red star's Avatar
well, it was the pump the whole time. good thing i can get a refund on it.
Old May 6, 2010 | 07:21 PM
let me guess,,, it was a walbro pump.
Old May 8, 2010 | 06:41 AM
2fast4u88's Avatar
Walbro's aren't that bad for burning up. If you look a all the threads out there. It is the stock relay that goes crazy. A guy I know replace his 2 or 3 times as it kept acting like the pump where it was the relay. Racetronix pumps are walbro's also
92crimson
82-92 V6 Tech
20
Jul 22, 2021 08:03 AM
acjjen4459
Dec 11, 2011 04:39 AM
thegluefactory
Aug 15, 2009 02:36 AM
camaroboy
Dec 8, 2007 03:57 PM
freekstylejimmy
Jan 6, 2006 01:10 AM
