LTCC (LT1-to-LS1 coil conversion) install
#31
A little update, since I going to have to redo the drivers side bracket in order to clear the air box, I decided I would just redo both brackets. So I found a metal shop here in Tucson that is going to laser cut them for me. It's 100 bucks which I think is well worth it. All I have to do is drill the holes when I get them and paint them, which I'm thinking just black or chevy orange. But either way it's going to be 2 weeks at the most before I get the brackets, but everything else is ready to go. So the next weekend after I get those I'll be installing this thing and running. I HOPE!!!
Here's what the new brackets are going to look like.
![](http://i75.photobucket.com/albums/i302/ltiedeman/CF%20Stuff/CoilBracketSchems.jpg)
#32
Got my brackets today, had a local metal shop lazer cut these out for me. About 90 bucks but worth it not the make these again. Here's a pic.
![](http://i75.photobucket.com/albums/i302/ltiedeman/DSC04689.jpg)
They are .125" 5052 aluminum and nice, better than my handmade fab'd ones for sure, nice and clean.
#33
Finally working on this today and hopeing to finish it up. Got everything I need and got a nice bit of it done yesterday. I'll let you guys know how it goes. Wish me luck.
#34
So I worked on this from 9 a.m. to 6 p.m. today, 3 hours of that was putting spark plug wires together, those LT1 boots suck to stick wires through. I was getting so pissed and then finally figured out how to get it done. The first two hours I only had 3 put together.
But anyway, got it put together and it started up the first try. I was so happy I can't even explain it as usually nothing I do to the car goes that good. But immediately I could tell it was idling better. After cleaning everything up I took for about a 30 minute test drive and it doesn't stumble at low RPM's like it used to, the accelleration is way better, and it's running about 5-10 degrees cooler than it normally did. And it was usual conditions when I test drove it, which was frick'n hot. So all and all I'm pretty happy with it, I expect that I'll probably pick up a few MPG's also. But time will tell. Anyway, here's a few pics of the finished install and a parts price list.
LS coils from 6.0 GM truck - $64.00 bucks off ebay, used.
Taylor 8mm wires and LT1 boot kit - $110 from Jegs
http://www.taylorvertex.com/Products...rcatalog10.pdf - wires
http://www.taylorvertex.com/Products...rcatalog20.pdf - LT1 opti ends
LTCC module - $410 from Bob
Laser cut brackets - $90 from local shop
Misc stuff - bolts, nuts, electrical tape, paint, etc... - $40.00
Time invested - Total about 30 hours not including research
Got any questions, let me know.
![](http://i75.photobucket.com/albums/i302/ltiedeman/CF%20Stuff/DSC04699.jpg)
![](http://i75.photobucket.com/albums/i302/ltiedeman/CF%20Stuff/DSC04700.jpg)
![](http://i75.photobucket.com/albums/i302/ltiedeman/CF%20Stuff/DSC04701.jpg)
![](http://i75.photobucket.com/albums/i302/ltiedeman/CF%20Stuff/DSC04697.jpg)
![](http://i75.photobucket.com/albums/i302/ltiedeman/CF%20Stuff/DSC04698.jpg)
![](http://i75.photobucket.com/albums/i302/ltiedeman/CF%20Stuff/DSC04702.jpg)
![](http://i75.photobucket.com/albums/i302/ltiedeman/CF%20Stuff/DSC04703.jpg)
The green light meant I did it right.
![](http://i75.photobucket.com/albums/i302/ltiedeman/CF%20Stuff/DSC04696.jpg)
#38
This is a pretty neat mod. It seems like a lot of work for what basically seems to me to be an opti replacement.
Have you noticed an improvement in mileage? Do you know anyone who has had this in their car for a long term test?
#39
It has helped a bunch, I wish I could get it dyno'd just to be sure. But let me put it this way, I'm getting about 4+ MPG than I did before. With the A/C on it has more pull than it did before with no A/C on. I just got to get some new plugs and I think that'll add even more to it.
#40
This is one of those situations where I would love to see the before data (with your original ignition components), a complete ignition tuneup (opti/plug/wires/coil/etc) with data and finally see the data after doing the whole LTCC swap.
Just to be certain what the real benefits are compared to just replacing the opti.
If you get a 4+ MPG gain, then that is almost a 20% improvement for me (I get just over 20 mpg now) and that is a pretty big gain.
But, it is a pretty cool mod and definitely should last longer than the original opti would.
