LT1/LT4 Tech 1993-1997
lt4 conversion
Old Dec 18, 2007 | 01:07 AM
stangslayer's Avatar
Default lt4 conversion
i got a magazine called pace performance and there is a lt4 conversion that comes with the lt4 hotcam and heads in it. it claims to make 425+ has anyone used this setup or know someone who has? and is it safe to use with a vortech supercharger? thanks. here is the link to it http://paceperformance.com/index.asp...mp;ProdID=8300
Old Dec 18, 2007 | 01:32 PM
LT1RUNNER's Avatar
Default RE: lt4 conversion
I read an article about a build up using the same set up and the car was going to run a procharger also. They were able to use everything but the cam. They had to call Comp Cams for a cam made for supercharger applications. You might want to check that out before using that cam.
Old Dec 18, 2007 | 02:13 PM
yea ill look into that. ive just heard the compression is to high when you install that kit to run a supercharger with much boost at all.
Old Dec 18, 2007 | 10:20 PM
95slvrZ28's Avatar
Typically you run 6-7 pounds of boost, if you want to run anything more you either need pistons that will lower your compression or a head with a larger combustion chamber. I would strongly recommend you to look into aftermarket heads instead of the GMPP heads, you can get a head that flows a lot better for less money, or a head that flows WAY better for the same amount of money if you go with an aftermarket company. Check what AFR and Brodix have to offer.
Old Dec 19, 2007 | 12:53 AM
thanks for the advice the other thing i need to worry about is smog i live in nazifornia. i know the lt4 conversion is smog legal. but not sure of other setups.
Old Dec 19, 2007 | 02:31 PM
95slvrZ28's Avatar
The main thing that you would need to worry about is the cam profile, so if you get something similar in cam to the LT4 cam, you should be good to go. Most of the heads that you'd be looking at will be a street legal head (i.e. they have a "heat riser") although none of the LT1's had heat risers, so it's not going to make much of a difference. If you do end up getting a "race" head that doesn't have a heat riser just make sure that your car is warmed up before you go to get it tested, the only purpose of the head riser is to get the intake warmed up quicker by siphoning off some hot exhaust gas.
jcase350
Nov 17, 2010 11:26 AM
NEVERLETITDIE
Mar 8, 2010 11:06 PM
RubberDucky
May 8, 2009 04:42 PM
davefh
Aug 6, 2007 08:40 PM
davefh
Apr 3, 2007 10:05 PM
