LT1/LT4 Tech 1993-1997
LT1 water pump temp sensor
Old Apr 14, 2014 | 06:22 PM
sm515's Avatar
Default LT1 water pump temp sensor
I bought a new water pump from Summit. My old water temp sensor doesn't seem to want to screw into the new pump. Threads look perfect on both. Its as if the new pump needs a smaller temp sensor. maybe metric? I'm not off by much. Thoughts? Thanks.
93 Z auto.
Old Apr 14, 2014 | 06:32 PM
Which pump did you get, the GMB? If so, that's the one I've used, and the sensor swapped over no problem. Do the threads in the pump look messed up or dinged at all?
Old Apr 14, 2014 | 06:37 PM
sm515's Avatar
The tough stuff one.
http://www.summitracing.com/int/part...t/model/camaro
Flows 30 percent better.lol.
Threads look good. Ill try a tap I guess.
Old Apr 14, 2014 | 09:01 PM
MKCoconuts's Avatar
Before you go nuts with a tap, run to the local parts store (or any store that sells nuts and bolts) and find the NPT section. More than likely you can find an adapter. Usually any threads dealing with liquids will be NPT thread, not SAE or Metric
Old Apr 14, 2014 | 10:05 PM
should fit. get your knife out and run the tip of it around the last row of threads, see if that will straighten out any that are a tad outa whack, don't get crazy, just run it around a few times
Old Apr 26, 2014 | 10:49 PM
sm515's Avatar
I ended up buying a tap. Worked, doesn't leak, thx.
Old Apr 27, 2014 | 01:27 PM
lol, that works too.
Mitch Upton
67-69 V8 Tech
Sep 9, 2011 04:04 PM
jamesfs912
Oct 20, 2009 01:52 PM
95camz28
Nov 23, 2007 07:40 AM
gr8cars1
Jun 9, 2007 08:54 PM
chas
Apr 7, 2006 10:08 PM
