LT1/LT4 Tech 1993-1997
LT1 swap
Old May 24, 2009 | 03:00 PM
350rs's Avatar
March 2008 ROTM
Cool LT1 swap
Ive got my lt1 for the 89. Im going to get a fuel pump soon. Im going from TBI to the LT1 like said. I think i have read somewhere before that i can use the stock TPI pump and that it would have enough to get the job done. Is this true? Also, down the road i would like to pull the LT1 back out and hop it up a bit, would that pump be enough to support 450-500 ish horse? Nothing too radical, just enough to get into trouble with.. lol
Old May 25, 2009 | 02:25 PM
95slvrZ28's Avatar
Do you know what the flow rate is on your current fuel pump? If I were you I don't know if I would risk overheating my fuel pump and getting stranded somewhere, but that's just me. If you're looking to run 450-500 HP the stock LT1 fuel pump can probably support that, although it may be smart to pick up a Walbro 255 or something along those lines.
Old May 25, 2009 | 07:16 PM
350rs's Avatar
March 2008 ROTM
pump is getting replaced, im just confirming weather i can use a TPI system fuel pump or if i need something more to power a mildly cammed LT1 for now. Everything else will likely be stock untill i can build it how i want it
Old May 26, 2009 | 12:03 PM
95slvrZ28's Avatar
If you're replacing the pump anyway go for something bigger than the TPI pump.
3800_seriesII
Aug 14, 2012 07:24 AM
9434V6
Sep 8, 2011 11:51 AM
xXChipXx
Aug 1, 2010 10:39 PM
miclo88
Oct 15, 2009 07:38 PM
85z285.0
Jun 2, 2007 03:19 PM
