LT1/LT4 Tech 1993-1997
LT1 runs hot at idle
Old Jan 2, 2011 | 08:06 PM
  #21
Turbolag86's Avatar
Ok, that will be the next step.
Would putting a 160 degree thermostat do anything ?
Old Jan 2, 2011 | 10:31 PM
  #22
greenmachine96's Avatar
It will lower the temperature the thermostat opens. it might help but the car shouldnt be getting that hot with the one you've got in there. If the one you've got in there is bad that could make your car get hot.
Old Jan 3, 2011 | 09:00 AM
  #23
Turbolag86's Avatar
Ok, first I'm gonna test for exhaust gas in the coolant and then I think I will put a 160 thermostat in.
Old Jan 3, 2011 | 06:27 PM
  #24
Turbolag86's Avatar
Ok today I put a 180 degree thermostat in. Just a replacement.
When I pulled the old thermostat off, I got a good look at the coolant and looked really dirty.
So tomorrow I'm gonna bring it to the radiator shop and get it flushed.
They said they do a 2 hr flush.
Hopefully that will fix it.
Old Jan 3, 2011 | 06:57 PM
  #25
yes thats a very good idea. i thought you already flushed it.
Old Jan 4, 2011 | 08:48 AM
  #26
Turbolag86's Avatar
No I didn't flush it. I'm about to bring it to the shop.
I really wanted to do all the work on the car myself, but I don't have any type of flushing system for the car.
I'll post how the car does once I get it back.
Old Jan 4, 2011 | 05:49 PM
  #27
Turbolag86's Avatar
Here's an update.
It turns out the car is not running hot !
Its the gauge.
The new temperature sending unit I put in is not as accurate as the factory.
So They recommended installing another temperature gauge.
How hard is it to install that gauge ?
Old Jan 4, 2011 | 08:20 PM
  #28
not hard at all. gota run wires or tubing depending on if its mechanical or electric and install the sending sensor. they make a pillar gage pod. http://www.jegs.com/i/Auto+Meter/105/10211/10002/-1
Old Jan 4, 2011 | 09:22 PM
  #29
My guess is that its electrical, but I'm not positive on that.
Old Jan 5, 2011 | 07:50 AM
  #30
Turbolag86's Avatar
Thanks guys. That's the exact setup I wanted. I wanted a gauge pod.
