LT1/LT4 Tech 1993-1997
LT1 Rough at low RPM under load
Old Sep 27, 2009 | 07:19 PM
Cummins's Avatar
Default LT1 Rough at low RPM under load
New to Camaro's - bought a 94 z28 w\ 55k miles a few weeks ago. All the sudden the car started to shake at low rpm when there is a load on the car (brakes on at stoplight, pushing throttle at speed before downshift ect) The car sounds funny as if it is missing on 1 cylinder. This started happening after driving in the rain - can the opti get wet from just driving? I tried to avoid every puddle possible.. Let me know what things I should look for - as I am at a loss of where to start. Thanks!
Old Sep 28, 2009 | 09:08 AM
welch7122's Avatar
Hello and congrats on scoring a low mile car! I have the same one and since this car has very limited diagnostic capabilities you may have to keep running it until you can get the check engine light to come on and give you a code to work with. It may be worth your time to inspect the spark plug wires especially at the plug end for a loose or damaged connection. Of couse the opti's do go bad but your problem could be anything at this point. Another problem area is the intake bellow/boot at the throttle body. They are difficult to properly install and it is possible that it is torn or not fully on at the bottom of the throttle body. Good luck
Old Sep 28, 2009 | 10:36 AM
start with new plugs an see what happens. if the wires look old and cracked replace also. mine would not even run and i replaced the plugs and ran like a champ.
csmiddy
67-69 V8 Tech
Dec 9, 2012 10:12 PM
92RS FTW
82-92 V8 Tech
11
Apr 9, 2011 01:55 PM
cchoneycutt
Nov 6, 2010 01:54 AM
CJ51974
Jun 1, 2009 08:59 PM
Bonnie w/2000 v6 called Roxy
Apr 4, 2009 03:19 PM
