LT1/LT4 Tech 1993-1997
Lt1 problems to look for
Old Sep 5, 2010 | 11:59 PM
Vandee's Avatar
Default Lt1 problems to look for
ok so i may be picking up a 95 z28 that has some body damage and then swaping it into my 96 i dont wanna here the whole sell ur 6 and get a z i just wanna know what i should look for like any problems that i need to be aware of things to notice that will send any red flags as to problems with the engine/tranny
Old Sep 6, 2010 | 07:47 AM
umm 95 is obd1 and 96 is obd2, completely different ecu's. the 95 does however have a obd2 diognostic plug so the under dash wiring harness may work for the 95 setup but you will still have to deal with the under hood wiring. you would be better off to look for a computer and wiring harnesses from a 96lt1.
Old Sep 6, 2010 | 10:14 AM
The front cover and exhaust manifolds from the 96 engine will have to replace the ones on the 95 engine. The 96 PCM is looking for a crank position sensor, which calls for 96 front cover, and the 96 is looking for dual cats which require changing exhaust manifolds.
Old Sep 6, 2010 | 10:22 AM
Vandee's Avatar
what do you mean under the hood wiring? if i just take the lt1 out of the 95 and swap it into th 96 engine bay ill have all the wires from the 95 under the hood of the 96 its the same engine bay correct or are you say like where it goes thru the firewall?
i know ill have to do something about the airbag sensors but if i have a complete donnor car i dont see how the wiring will be such an issue unless im missing something
Old Sep 6, 2010 | 08:52 PM
now you raised a good question. in 96 the camaro switched to a obd2 computer system which is different than the 95 obd 1 with a obd2 plugin for diagonosing. the thing i dont know is if the two are compatable. i guess you will find out.
Old Sep 7, 2010 | 09:18 PM
Vandee's Avatar
^^ lets hope so but thats assuming i can convince my dad to lend me the $800 bucks to buy the Z
Old Sep 8, 2010 | 06:05 PM
loolagigi's Avatar
pretty cool. i have really been learning. thanks for being here everyone.
mp734
Nov 6, 2013 11:54 AM
nmallory56
Jul 21, 2009 03:34 PM
IZZY1967RS
Jun 19, 2008 10:29 PM
jdubs1813
Nov 12, 2007 04:16 PM
Nov 11, 2007 11:56 AM
