Lt1 performance cams
well that only took me like 20 seconds, lol. here is something you should read..i know its about stock heads...but i learned a lot from it and its a good starting ground when looking at cams. also, if you're looking to do some headwork at the same time, go to www.elliottsportworks.com and talk to lloyd about your goals and he can set up a heads/cam package that will fit your needs well. here's the link
http://www.ls1tech.com/forums/lt1-lt...wap-guide.html
To the OP, by your first initial post it sounds like to me youre just after the sound, which is what 98% of the people are after, do what whammer said or you can contact comp cams and they can also help guide you
