LT1/LT4 Tech 1993-1997
LT1 oil pressure
Old 10-11-2009, 09:37 AM
divineal's Avatar
well mine is always below the first line about halfway to there i think equivalent to 10 pounds pressure is that bad?
  #22
Old 10-11-2009, 09:56 AM
PAzYearazzUP's Avatar
10lbs per 1,000rpm = If you are revving up to 6,000rpm, a good pressure number reads 60psi.
Short of installing new cam bearings, sort of drop the crank, also remove rod caps = Install new, tighter fitting bearings. Even use different size bearing inserts on one side of the half cap(s) or "C" clamp(s). To shrink the diameter around the journals, you mis-match bearings, they still press "round" in a perfect circle as if both bearing inserts were even as well. < Old School.
  #23
Old 10-23-2009, 09:22 AM
I found a leak on the timing cover. Has anyone every replaced the seal and how labor intensive is it?
  #24
Old 10-23-2009, 12:17 PM
try a little heavier wt oil. 20w40 something like that.
  #25
Old 10-23-2009, 12:21 PM
yes camaro 69 has.
https://camaroforums.com/forum/lt1-lt4-tech-9/installing-water-pump-drive-seal-43601/
royco95
08-02-2015 10:25 AM
BoricuaHec01
LS Series Tech
03-17-2011 05:56 PM
angelus
02-20-2010 01:17 PM
fitz796
09-28-2009 03:10 PM
IBSTROKIN
09-09-2009 10:40 PM
Quick Reply: LT1 oil pressure
