LT1/LT4 Tech 1993-1997
LT1 isn't fireing.
Old Mar 8, 2009 | 05:21 PM
Originally Posted by KawasakiJ14
i changed the ignition "control" module. is there a difference between that and a "coil" module?
By the way, i replaced the coil and the car still won't start. I may as well change the wires leading into the coil from the harness. If the fuel system has checked out, and im getting spark (at least i think i am) can there be a bad sensor like MAF? will a bad MAF sensor cause the engine to not run? Could it be a bad cam position sensor?
im getting annoyed cause i keep dropping money into this thing without any luck. the only plus side is that I'm getting new parts lol.
Any more ideas?
1)Ignition contro & coil module are the same thing.
2)The car can run without the MAF.
3)There is no cam position sensor.
4)Just because you have fuel pressure does not mean that the injectors are firing. Check the two injector fuses, if OK get a set of NOID lites and verify that all the injectors are firing.\
5)IS THE CHECK ENGINE LITE LIT?
Old Mar 9, 2009 | 07:13 PM
blue 95 camz28's Avatar
Did you try to see if your altenator is working properly.You can run on a charged battery if the altenator is bad then u will kill the battery(Approx 10 min of run time)
