LT1/LT4 Tech 1993-1997
lt1 compression
Old Jan 28, 2011 | 11:13 AM
LT1ChevyBoy's Avatar
Default lt1 compression
I figured when trying to make a 500 hp motor i would improve the compression ratio but when i asked the guy at jegs he said they come stock with 10.5:1 compression i was just wanting to double check these figures because i already shaved the heads and now im already worried about not being able to use pump gas
Old Jan 28, 2011 | 11:36 AM
Stock compresssion on a LT1 is 10.4. Depending on how much you shaved the heads, you may have to buy AV gas at your local airport. You can blow off some of the compression effects by going to a long duration cam.
Old Jan 28, 2011 | 12:26 PM
i talked to lloyd elliot and is advice was to not go passed a .615 duration
Old Jan 28, 2011 | 03:52 PM
That would be lift, duration is measured in degrees.
Old Jan 28, 2011 | 04:26 PM
z28rob18's Avatar
theres ppl running these motors with 12:5.1 compression on 93 pump gas. my motor is goin to be 11:66.1 its mostly in the tune. i wouldn't go higher than 12:1
Old Jan 28, 2011 | 10:12 PM
thanks guys
NorthernCrew454
Oct 17, 2011 09:30 AM
BasicConcepts
Sep 11, 2010 03:14 PM
BasicConcepts
May 7, 2010 06:43 PM
z-28foxx
Feb 10, 2010 11:33 PM
Bennyt900
Jun 1, 2007 10:22 AM
