LT1/LT4 Tech 1993-1997
Low coolent light on
Old Feb 23, 2009 | 09:33 PM
Vanderkooy325's Avatar
Default Low coolent light on
I own a 94 z28 and the low coolent light is on but its dim. I check the fluid level frequently but it is good and my temp stays at a good temp. What could be making it do that and what can i do to make it go off
Old Feb 23, 2009 | 09:54 PM
Saint_Ali's Avatar
ive had mine over 3 years and it comes on a lot for no reason, you just have to learn to ignore it if you know the coolant is full
Old Feb 23, 2009 | 10:16 PM
lt4weeda's Avatar
Same here. Check it frequently even changed the sensor comes on all the time. I just make sure I check the level on a regular basis and don't let the temp get to high
Old Feb 24, 2009 | 07:05 AM
The level sensor in the radiator gets crudded up and starts acting up. You can remove and give it a good cleaning and put it back to see if the problem stops. Otherwise you can put in a new sensor, or just short toghether the two wires going to the sensor.
Old Feb 24, 2009 | 03:11 PM
torque_is_good's Avatar
quoted for truth. Bypass the damn thing and just keep performing your under hood fluid checks.
chevyman510
Jun 7, 2012 11:58 PM
danstheman454
Apr 17, 2011 08:17 PM
Chevy101
May 11, 2009 08:40 PM
superROB23
Oct 2, 2007 02:15 PM
bluovlh8er
Mar 22, 2007 10:38 PM
