LT1/LT4 Tech 1993-1997
low coolant light
Old Dec 15, 2006 | 05:47 AM
Saint_Ali's Avatar
Default low coolant light
my low coolant light has been coming on, but when i check the coolant level it is a full hot, it gets annoying driving and having the light come on, any suggestions ?
Old Dec 15, 2006 | 06:05 AM
sewerrat's Avatar
Default RE: low coolant light
The sensor tends to crap out after awhile. You might try removing it and cleaning the sensor tip and see if that helps or you can replace it. I think they run around $40.
Old Dec 15, 2006 | 12:15 PM
shnormo's Avatar
You can thank Dexcool for that.
Old Dec 15, 2006 | 08:54 PM
SLJ2137694's Avatar
Low coolant sensors were going bad long before Dex-Cool! There is nothing wrong with Dex-Cool when properly used and maintained. A couple of important things are: don't mix it with other types of coolant and be sure your radiator is completely full. If it runs low you will introduce air (oxygen) into the system and that air will then attack the unprotected portions of the cooling system. This is where the sludge complaints come from. Vehicles that I have seen with sludge had radiator caps that were not working properly. When the engine cooled down the caps were not allowing coolant to be sucked back into the radiator and that created the low coolant level with the associated air in the system. Millions and millions of vehicles are working just fine with Dex-Cool.
bill2129
Jul 24, 2011 10:42 AM
xXChipXx
Oct 25, 2010 01:05 PM
evilbeef54
Jul 27, 2008 09:47 PM
stud1502
Sep 17, 2007 04:54 PM
Z28man
Oct 6, 2006 09:41 PM
