LT1/LT4 Tech 1993-1997
Looking to Buy New Plug Wires
Old Mar 31, 2011 | 05:59 PM
i use photobucket and copy the img code to the post. not sure you cqn do thqt with imageshack. ahh and yah wires and plugs are a pita, lol. sounds like round two may go better.
Old Mar 31, 2011 | 06:34 PM
Turbolag86's Avatar
Hey Craby, how are your wires coming along ?
Old Mar 31, 2011 | 11:01 PM
havnt had time to work on the car. been dealing with a buick 3800 on my pot pump and my van. pretty much got the pump goin good, today i found i am gona need a new suction hose. lol,,, that sucks.
Old Apr 6, 2011 | 09:47 AM
Turbolag86's Avatar
Hey everyone. Sorry it took me until today to post the pics. But here they are.
All finished.
The first day was difficult because I think I overwhelmed myself thinking about all what had to be done. But I took the next day to devise a plan. After doing that I was able to finish the wires the following day. They really aren't THAT bad. The biggest issue I had was getting the boots to slide over the wires before I crimped the terminal.
The directions say to use WD40 or Silicone spray, but I didn't have Silicone spray and the WD40 wasn't really helping.
My dad recommended Axle Grease....That worked a lot better. I still had some difficulties getting the boot on. With some wires I had to put grease on them and slide them on and they would make it about half way, then I would have to pull them off and re apply grease and then they would slide through.
The hardest spark plug to snap the plug wire on is the #6 cylinder on the passenger side because the dipstick is right next to it. I thought I was gonna have to remove the dipstick bolt....but that would have meant taking the starter off ! Use your right hand to slide it up between the header and the starter. There is one plug to disconnect...but its really easy. Squeeze the middle of it and it slides off...Not sure which plug it is.
Also, make sure you cut the wires LONG....I almost cut a wire too short, but it worked out ok...whew.
I'll take some more pictures if you guys want to see any more of them.
https://camaroforums.com/forum/%3Ca%20href=%22
Old Apr 6, 2011 | 10:21 AM
look great. did you use electric grease. that would have been best.
Old Apr 6, 2011 | 12:26 PM
Turbolag86's Avatar
I don't know if we have any electric grease or not.
I thought about using Vaseline. But the axle grease worked out ok.
Next time, I'll be more prepared ! Haha.
Also there are a couple screws missing out of the looms in the pictures....I hadn't tightened everything down yet. Now all the screws are in place..
Oh hey Craby I wanted to tell you....you are probably already aware of this but just in case....when you push the nut out of the looms for the longer screws to screw into the brackets....I don't know if you can get your fingers under there or not for the nut to go in....I couldn't but I have big hands....I just super glued them on.... On the bracket where the nut sets in place for the longer screw.
Just putting that in there....You probably already know that, but just in case.
Old Apr 6, 2011 | 03:27 PM
torque_is_good's Avatar
next on the agenda for you
lose that plastic intake elbow with donkey di$$^ and get a good looking elbow
Old Apr 6, 2011 | 06:12 PM
Turbolag86's Avatar
Yea Whammer showed me some Trick Flows that are nice.
I wanna get a polished intake elbow and a Chrome Alternator...They have one at a shop in town...150 for it.
I think that would look nice.
numskull223
Oct 20, 2011 11:12 PM
osduck5
Oct 20, 2010 08:11 AM
Jonny Dubyah
Jun 4, 2009 10:49 AM
thebandit110
Oct 23, 2007 09:18 PM
srober76
Aug 12, 2005 11:36 PM
