LT1/LT4 Tech 1993-1997
le2 setup
Old Mar 15, 2011 | 03:40 PM
sgtdupree's Avatar
Default le2 setup
im saving to get the le2 set up from llyod. he gave me a list of things ill need to make this work.
CAI
exhaust
1.6 roller rockers
push rods
30lbs fuel injectors
stall converter
tune
timing chain
all this stuff together is pretty pricey and im a right now type of person. is all this a must before i get the le2? or can i get the le2 and get this this stuff over time (maybe a month later)? this isnt my daily driver but i do drive it around. what do you recommend?
Old Mar 15, 2011 | 03:49 PM
Massey's Avatar
Get the stuff first then do the work. If you put the engine in then get goodies like a stall converter, timing chain, or the rockers you are going to have to pull the engine apart, or the trans out to get the stuff in and done properly. Timing covers are not fun to change in car and have a bad habbit of leaking after you are done. Things like the CAI and exhaust can be done later. Remember this is all gonna need a tune to run right, your LT1 profile will get you started but not running as good as you can.
Massey
Old Mar 15, 2011 | 08:23 PM
you already have headers? yep need to get most of the stuff on the list then do it. what cam you usin?
Old Mar 15, 2011 | 09:30 PM
timmyz28's Avatar
yeah he told me just about the same thing, and i told him i wanna get a 396 forged lt1 with le2 heads and p/p intake by him, so he can make a custom size cam for my future build. you can tell him what you want from the car. ie-street rod, drag car, nice cruiser, etc. and you can get a cam from him or he can design a cam to your likings.
Old Mar 16, 2011 | 08:14 AM
sgtdupree's Avatar
yeah ima get the le2 with his cam similar to the cc 306 cam. i already got long tubes.i was gonna do the common sense thing and put the motor suff on at the same time i.e. timing chain, push rod, and roller rockers. but can i get by for a minute wit jus that. can i hold off on the 373 gear the stall converter cai and injectors?
Old Mar 16, 2011 | 09:20 AM
with that size cam your gona want the stall ande injectors in.
Old Mar 16, 2011 | 09:23 AM
whammer3024's Avatar
ROTM Winner
craby is correct here
Old Mar 16, 2011 | 02:18 PM
sgtdupree's Avatar
thanks
Old Mar 19, 2011 | 08:57 PM
greenmachine96's Avatar
Hey im curious about doing the same thing in the future and was wondering if you know about how much all of these mods would cost you?
kaspar
Dec 27, 2008 01:15 PM
LoudMouthSS
Jul 7, 2008 06:50 PM
buckfever
Dec 18, 2007 07:35 PM
80sbaby
82-92 V8 Tech
Jul 1, 2007 03:11 AM
2fast4u
12
Dec 11, 2006 11:06 PM
