LT1/LT4 Tech 1993-1997
Keep dumping coolant
Old 07-14-2011, 08:26 PM
ok. check the hose that goes from the radiator to the overflow tank.
Old 07-14-2011, 08:42 PM
Bjdavi08's Avatar
I have already replaced that
Old 07-14-2011, 09:32 PM
so you have replaced the overflow hose and the container? the container gets abused being under the battery.
Old 07-14-2011, 10:03 PM
Bjdavi08's Avatar
When i replaced the overflow, it came with a new hose
Old 07-15-2011, 12:00 AM
you have a leak somewhere. either you got a bad hose or a crack in the fitting on the radiator or in the new container. can you track the leak, clean and dry everything then fill the sytem and bring the motor up to operating temp, turning it off once in a while to look for signs of a leak and where its coming from. if its what i think it is its pushing coolant out as it heats up and sucking air in as it cools
Old 07-16-2011, 03:10 PM
Bjdavi08's Avatar
ok well, I think that it might be something bigger. Cousin came over and looked at it, he said it might be a head gasket or a cracked head.
Old 07-16-2011, 03:15 PM
that would do it,,, strange it didnt show up on the pressure test.
Greg08
10-04-2012 09:31 AM
threevolve
08-21-2012 12:18 PM
Camaro3800V6
08-17-2011 03:47 PM
AnalyzeFaith
12-05-2010 05:54 PM
TRIPSxZ28
82-92 V8 Tech
26
09-21-2007 10:11 AM
Quick Reply: Keep dumping coolant
