LT1/LT4 Tech 1993-1997
Just Another Overheating LT1 :-/
Old 11-29-2010, 10:57 PM
Originally Posted by Palmbach195
So I got the air dam and put it on... the car runs right at 180 while I'm driving and doesn't move... it only heats up when I'm sitting at a stop light and the fans come on and cool it right down... and as soon as I drive the fans shut off.. does this sound like its doing like it should?.....
Yes, with the air dam back on, your cooling system is now working like it was designed to.
  #42
Old 11-29-2010, 11:37 PM
Jared Cassedy's Avatar
Originally Posted by craby
drill a hole in top of the brass t you have there and tap it for a screw. see if you can find a bleeder screw at a wrecking yard or dealer and tap to that screws thread and size. otherwise im sure you could take it out till the air is gone. maybe drill, file or dremel the screw part way up in a small spot so air can get out when its losened.
so since i dont have that screw, all of the air wont come out?
  #43
Old 11-29-2010, 11:38 PM
i would,,, water pump is spendy.
i went to auto zone here in vegas where i live and they have a water pump for only $48.99. doesnt seem spendy to me lol
  #44
Old 11-30-2010, 07:02 AM
sorry the 93 is the only yr with the bleeder on the tb. my bad.
Oh ya one more thing... craby, you said something about a third bleeder screw in the throttle body? I couldn't find it when I was looking... where is it located on the throttle body?
  #45
Old 11-30-2010, 07:10 AM
where that bleeder is is where the air really likes to hang so i would say yes all the air will not come out without a bleeder there.
if you want to put a cheap rebuilt water pump over your opti its up to you. i dont recomend it.
  #46
Old 11-30-2010, 04:16 PM
Idk if it's rebuilt or not and idk what an opti is.
  #47
Old 11-30-2010, 04:32 PM
opti is the distributor on the 93-97 lt1 and if the water pump is at that cost, it is the rebuilt.
  #48
Old 11-30-2010, 04:44 PM
oh i see.. comes with a warranty. how much would a non rebuild one be? i dont have much but i I'm hoping by not having a 3rd bleeder screw thats why it still overheats.
  #49
Old 11-30-2010, 04:46 PM
a water pump failing will not cause a lt1 to overheat, that is untill the coolant level drops. if your water pump is not leaking its ok. new water pumps run about 150 bucks. like i said spendy. and the bleeder screw on the throttle body is not needed, i guess or gm would have left it there. you can bypass the throttle body with a piece of pipe and a couple of hose clamps.
  #50
Old 11-30-2010, 05:01 PM
i have the bleeder screw on the tb and the thermostat hosing, just not on that brass hose thing
Quick Reply: Just Another Overheating LT1 :-/
