LT1/LT4 Tech 1993-1997
injector size
Old Dec 13, 2010 | 10:50 PM
carguylt1's Avatar
Default injector size
I have been looking at injectors for a while and just not sure what size to go with for the mods i'm doing. 95Z 6 speed cold air,electric water pump, long tubes, 3" exhaust, mild cam, 2.02/1.60 valves, p&p, .030 over 8.5:1 pistons. May shave the heads a little and deck the block. I know I will need a pressure regulator and may be a bigger throttle body.
Old Dec 13, 2010 | 11:01 PM
52mm tb is in order, what rockers are you useing? i am having good results with 30lb bosch style. had them flow test them before sending.
Old Dec 13, 2010 | 11:06 PM
carguylt1's Avatar
1.6 rollers would like to force induction it next. could I run a bigger injector than needed and turn down the regulator?
Old Dec 13, 2010 | 11:12 PM
i was looking at the ford 32lb ones that will flow to 36 or 37 with the pressure turned up but figured id wait and see what a dyno tune showed.
Old Dec 13, 2010 | 11:14 PM
carguylt1's Avatar
Thanks let me know how that goes.
Camaroboi22
May 7, 2012 10:39 PM
pimpjuicepd
Apr 2, 2011 04:27 PM
draggo144
82-92 V8 Tech
Dec 7, 2009 10:57 AM
sewerrat
Aug 8, 2009 03:16 PM
sewerrat
Jun 13, 2006 06:32 AM
