ignition coil
Hey guys, I bought an msd coil and i was wondering if the box is really necessary for proper function. i can connect the coil by itself but im not sure if i should leave it like that. my car is a 95 z28. thanks
Those boxes just give you 2 or 3 high voltage pulses per cycle instead of the 1 that the stock units provide. The newer 6AL units can even assist in some timing adjustments as well as a rev limiter for racing applications. The coils that MSD make are supposed to work just fine for factory applications but they have a higher refresh rate than the factory coils do so they have a faster response. (basically in laimmans terms they fire faster).
Massey
Massey
