LT1/LT4 Tech 1993-1997
IAC replacement.
Old Nov 10, 2020 | 09:37 AM
  #31
95z28man's Avatar
I had the plugs check recently, all good. It does tend to start then die, then the next turn of the key it will either start fine or just turn over for a while. I've been getting around it temporarily (because I've been lazy about getting it back in the shop because it's been in so many times this year) by just giving it gas as soon as it kicks over.
Old Nov 11, 2020 | 04:04 PM
  #32
HenryC's Avatar
And when you give it throttle while cranking it'll start most of the time?
Old Nov 12, 2020 | 06:46 AM
  #33
95z28man's Avatar
Yup. As soon as it fires I just blip the throttle so it revs to maybe 1500-2000 rpm for just a second. Cycling the the key a few times to get the fuel pump primed doesn't seem like it's made it act any different. When I crank the first time (not giving any gas) it'll fire/sputter, then die. Then it's luck if it'll either fire up the next attempt, or just turn over for a while without firing.
Old Nov 12, 2020 | 11:50 AM
  #34
HenryC's Avatar
Hmm well since it doesn't seem to be fuel related I'd guess that it were your IAC but you just replaced that, it could be a bad MAF
Old Nov 12, 2020 | 11:51 AM
  #35
HenryC's Avatar
Try unplugging your MAF and starting it, if it fires up first time it's probably your MAF, it'll run rough once it starts because it has no airflow info but as long as it starts with it unplugged it's pointing towards your MAF sensor
Old Nov 13, 2020 | 06:49 AM
  #36
95z28man's Avatar
Thanks. I'll try to look into that this weekend. It's possible the new IAC is crap too I've considered. I got both the IAC and TPS and Oreilly and they gave me the wrong TPS. The IAC looks exactly the same except the plug on it faces the opposite direction.
Old Aug 30, 2023 | 04:43 PM
  #37
32rdstr's Avatar
I know this is an older thread but I have a question regarding the IAC. What does the oil cooler have to do with the IAC?
Old Aug 31, 2023 | 03:18 PM
  #38
Nothing, Oil coolers where optional thing and GM just added them. They were bought from Mr. Gasket or one of the known aftermarket manufacture. There is no electricity or sensors. It just some pipes that flows oil to the front of the car to be cooled. The IAC (Idle air control) motor. Is a part the fuel injection system and is run by your computer so your car idles at the right RPM. What would make you think they are related?
Old Aug 31, 2023 | 07:01 PM
  #39
32rdstr's Avatar
Well Gorn it was mentioned several time in this thread AND Rock Auto list two different part numbers for the IAC, one with oil cooler and one without. So, my question still stands, what does the oil cooler have to do with the IAC? Or put it another way how can the oil cooler effect the IAC?
Old Aug 31, 2023 | 11:25 PM
  #40
rock auto has corrected it. only shows one type now.
Mikeroc283
Nov 16, 2013 05:10 PM
skinut
Dec 27, 2011 01:24 PM
imcdowel
Nov 27, 2010 01:14 PM
86CamaroZ28
Sep 7, 2010 08:25 PM
davex45
Apr 21, 2008 09:57 AM
