LT1/LT4 Tech 1993-1997
I think my fuel pump is done
Old 12-17-2010, 04:35 PM
xXChipXx's Avatar
Default I think my fuel pump is done
My car will sometimes run a little bad (misses, hesitates), and then after a bit it warms up and works itself out. Then if I go to dive it maybe half an hour later is spits and sputters bad. Sometimes it does start hard. I hooked up a fuel pressure tester up and it does read low, (like 20-25). And if you rev it at idle it drops to about 18-19. Think my pump is going out, or is there a sensor or something I can rule out first?
Old 12-17-2010, 06:37 PM
only other thing i can think of is the fuel pressure regulator. bad relay should make the pump not work at all. not low pressure but no pressure.
Old 01-20-2011, 03:12 AM
96ZLT1's Avatar
i was wondering if you got the problem fixed and what it actually was that was causing it to run like that?
Old 01-22-2011, 12:37 AM
xXChipXx's Avatar
Yeah I did, it ended up being my fuel pump. It was running about half psi (18-23Lbs)
Old 01-22-2011, 03:40 AM
96ZLT1's Avatar
mines running 12psi. im trying to figure out if its the pump or fuel pressure regulator. its been like that for a several month and i currently dont have a job so its kinda hard to scrape up 200+ for the pump. what pump did you use in yours?
Old 01-22-2011, 05:48 PM
xXChipXx's Avatar
Just the $170 pump from auto zone. If you do end up replacing the pump, I recommend that you cut a hole out in the hatch. Way better than dropping the tank. Turns it into a 20 minute job
Old 01-22-2011, 09:07 PM
96ZLT1's Avatar
that was my plan. lol
Old 01-23-2011, 12:27 AM
sgtdupree's Avatar
I'm havin the same issue. somebody on here told me that's what my problem was. I let tge shop talk me into gettin a damn fuel system cleaner what a rip off.
Old 01-23-2011, 01:11 AM
96ZLT1's Avatar
i sea foamed mine when it first started, i dont know much about it but i think it made it worse.
Old 02-17-2011, 07:43 PM
xXChipXx's Avatar
If your running low pressure it could be the regulator, pump or even the filter. I would replace the filter no matter what.
Quick Reply: I think my fuel pump is done
