LT1/LT4 Tech 1993-1997
i need help with my trans....
Old Feb 27, 2008 | 02:44 PM
noz's Avatar
noz
Default i need help with my trans....
i have a 1995 camaro z28 i berly bought the car i dont know if is the trans. or the clutch, the problems starts when im in neutral, the trans starts to grind and in first gear too..after that the car is perfect. i'll appreciate if someone can help me thanks.
Old Feb 29, 2008 | 04:25 PM
DrRuckus13's Avatar
Default RE: i need help with my trans....
Transmision Problems are really expensive. If you just bought it you might want to consider taking it back. From Experience, Mine was an auto and cost $2750.00 to put a new tranny in it. [sm=sorry.gif]
Old Feb 29, 2008 | 04:35 PM
libertyforall1776's Avatar
Whatever you do, put Dexron 6 (not 4) in when you replace the fluid -- it's a MUCH longer life fluid...
Old Feb 29, 2008 | 07:47 PM
The grinding going into first is probably due to a bad synchro. Shift to second & back to first, and that should tak care of the grinding. At least till the 2nd gear synchro gives out.
mxr81999
Aug 16, 2012 07:26 AM
olered
Nov 13, 2011 08:52 PM
libertyforall1776
Sep 13, 2011 12:28 PM
Spartan66
11
Dec 8, 2008 02:59 PM
thebandit110
Jul 28, 2007 06:54 PM
