LT1/LT4 Tech 1993-1997
Hypertech Tuner Effectiveness?
Old Sep 6, 2010 | 02:12 PM
TransAmGuy95's Avatar
Default Hypertech Tuner Effectiveness?
I was looking online for a "tuning" device so that I dont need to take my car to a shop to fix the odometer and speedo when i change gear ratios. I found a hypertech tuner and I was wondering what they do exactly and if they are worth the money. I also was wondering if the "performance tune" it comes with does anything.
http://www.streetsideauto.com/produc...l&lsbEngVins=P
Old Sep 6, 2010 | 03:14 PM
TheImpalaMan's Avatar
I had a Hypertech tuning box, and yes you can change out the gear ratios on the computer easily with it. But if you want real horsepower gains from computer tuning, I'd recommend getting it dyno-tuned or talk to Bryan Herter over at PCMforless.com. He's a great computer tuner. If you are worried about downtime, what you can do is find yourself a second computer that can run your car while you are getting your main PCM tuned. The Hypertech didn't do much for the performance in my LT1 but lean it out a bit. I got rid of that box and use Bryan for any computer mods. Take Care.
-ImpalaMan
Old Sep 6, 2010 | 11:15 PM
hypertech is not something you want to get into. if you want to tune yourself youll need a couple cords and some buning equipment. check out what moats has. most guys that cant get a dyno tune done will use a place like pcmforless or lt1pcmtuning.
http://www.moates.net/
http://www.pcmforless.com/index.php?...d=16&Itemid=38
http://www.lt1pcmtuning.com/
Old Sep 6, 2010 | 11:28 PM
Wac137's Avatar
I can tell you from actually having and using a Hypertech tuner that it will help out performance wise a little bit and yes you can change the rear gear ratio and speedo and all that with it.
CRISISS
LS Series Tech
Nov 21, 2011 09:39 PM
TheHuffman
Sep 25, 2011 03:56 AM
AmirGTR
Sep 7, 2010 08:19 AM
forpinks
Nov 13, 2007 06:08 PM
Billy
Jun 13, 2007 04:09 PM
