LT1/LT4 Tech 1993-1997
How low can I go?!?
Old Nov 13, 2008 | 01:40 PM
im74d's Avatar
Default How low can I go?!?
I have a 1995 Z28 and am planning to get 19inch rims so I was wondering what is the most I would be able to drop it before I start hitting wheel wells and stuff.
Also, if there is anyone that can help with interior panels of the color black or similar???
Old Nov 13, 2008 | 02:11 PM
Spartan66's Avatar
Default RE: How low can I go?!?
Your best bet would be to get the wheels and everything installed at stock ride height and then measure the room so you kno exactly how low you need to go. Because we could guess at numbers all day and still possibly be wrong.
Old Nov 13, 2008 | 07:12 PM
importmd's Avatar
i have 17"s and dropped 2", i cant go any lower. so i dont think you can drop your car much if any with 19"s
Old Nov 14, 2008 | 12:50 AM
drumr2790's Avatar
If the 19 inch rims have a tire profile that matches those of your 17 inch rims (i.e. the tire height with the 19 inch rims is the same as the stock tire height), he could drop it the same amount (or whatever the lowest you can go on stock height tires is).
Old Nov 14, 2008 | 01:20 AM
im74d's Avatar
I really appreciate the insight. The wheel are being ordered from the web and they do adjust the tires to make them the same height as the stock height. So max of 2 inches. I have also been reading on Camber kits? not sure what that is or where to get them. I am on a budget so is it something I have to get with the springs?
