LT1/LT4 Tech 1993-1997
High beams!
Old 03-16-2010, 12:45 PM
drewski's Avatar
Location: Katy/Richmond, Tx.... on the West side of Houston....
If I can find the link I saw a month or so ago I'll post it, but essentially the switch needs to be adjusted... its going to take a little set of arms and patience, but its easy... after you get the 2 panels off under the steering wheel there are 4 nuts that hold the steering column up... 2 of them hold a brace thats under the column, and 2 of them hold the actual column... if you undo those two the column will drop, allowing you to see the switch and linkage from the top of the steering column... there are 2 bolts holding it where it is and it is set up to be adjusted... loosen the 2 bolts and slide the switch towards the steering wheel... i tested mine a few times to make sure i had the right pull on the switch... its not really hard, its just a pain to be able to loosen the 2 bolts on the switch itself...
like i said, if I can find the link, I'll post it later...
Old 03-16-2010, 07:25 PM
jjz28's Avatar
cool drewski, I'll have to check into that.
Old 03-19-2010, 12:14 PM
Skippysnax's Avatar
nice diagram craby what book is that? haynes?
Old 03-19-2010, 06:46 PM
its a factory service manual for a 93 camaro. i dont mess with the aftermarket books.
JPrice
03-01-2014 10:25 AM
mrdreex
02-16-2011 10:44 AM
redstarz808
02-16-2009 07:26 PM
StratcatDeville
08-29-2008 11:39 PM
91camaro305rs
07-24-2006 04:46 AM
Quick Reply: High beams!
