LT1/LT4 Tech 1993-1997
Hesitation/studder
Old 01-07-2010, 01:27 PM
94zmaro's Avatar
Yeah I would think it would have more adverse effects if it were the fuel filter. I think I was hoping for an easy fix. Once the car gets warm or hot the idle does change from a contant steady idle to an idle which goes from a grand and spurts up to 1200 and back down to a grand.
Old 01-12-2010, 08:45 PM
murderd96z28's Avatar
Originally Posted by torque_is_good
Oh, and to Z28pete, I won't be doing the egr this weekend either because it's only suppose to be in the high 40's during the day, brrrrrrr
Damn, I'm going to buy a snuggie
thats some funny crap man
my damn car is doing the same thing, i got 02 codes, but replace the 02 sensor that it said it was bad and its still doin it, the check engine light is on and if i keep driving it the light starts to flash at me then stop but still stays on, i replaced the fuel filter, didnt do anything
Old 01-13-2010, 03:32 PM
now my car is throwing a po300 which is random cylinder missfire, which that is causing the 02 to throw a code because of the missfire, so now i get to replace plugs and wires.
im sure its not the opti, car has under 40k and i have the newer vented styl, but it could use new plugs anyway
Old 01-14-2010, 07:46 PM
94zmaro's Avatar
Yeah I just replaced the fuel filter and nothing changed which I thought would be the case. Its really random when it wants to jump or hesitate.
Old 01-14-2010, 09:02 PM
have u checked all the wiring, spark plug, coil and ignition modual wires. sure could be a wire not connected completely. really dont want to say this but could be the opti on its way out.
Old 01-15-2010, 11:14 PM
Justin_97_CamaroSS's Avatar
hey check all your spark plug wires because if you have long tube headers they could have burn the spark plug wires. You can turn your car on at night with the lights out and just look at your ignition coils and wire to see if they are arcing if they are then. Make sure none of your wires are lose or breaking apart make sure the you feel them because some times it look fine and then falls apart in your hand.
Old 01-30-2010, 07:21 PM
94zmaro's Avatar
Yeah I will definately check out all the suggestions. Havent had time to yet. JUst throwing this out there but could it be my tps?
Old 01-31-2010, 11:57 PM
replaced all the plugs and wires on mine and it fixed the problem
Old 02-05-2010, 07:50 PM
94zmaro's Avatar
Replaced the tps and that didnt fix it. I did get to look at the plugs at night and saw that the wires are bad so I will be replacing them and hopefully that fixes the problem.
  #20
Old 02-05-2010, 07:55 PM
jeff2285's Avatar
try for the coils
Quick Reply: Hesitation/studder
