LT1/LT4 Tech 1993-1997
Help my car shakes violently
Old Aug 5, 2009 | 09:16 AM
divineal's Avatar
Default Help my car shakes violently
ok so heres what happened my car was inoperative for a few months and now i finally fixed it but it seems to shake terrible mostly in 6th gear idk what could be wrong help any ideas?
Old Aug 5, 2009 | 10:47 AM
95slvrZ28's Avatar
Is the shaking related to speed, rpm, just 6th gear???
Old Aug 5, 2009 | 10:58 AM
6th gear is a double overdrive. Unless you're cruising well past highway speeds on flat ground, don't even bother using 6th gear. If you're popping it in 6th at low speeds, you're lugging the engine down, and that's most likely what you're experiencing.
Old Aug 5, 2009 | 01:29 PM
divineal's Avatar
well before it got messed up it wouldnt do that and if it would shake it would be mild and now its shakes very violently like if the tranny was gonna fall off and its relative to rpm i guess but its not noticeable till like 4th geear and as i go into higher gears it worsens
Old Aug 5, 2009 | 01:37 PM
what did u fix?
Old Aug 5, 2009 | 01:54 PM
divineal's Avatar
just an ignition sensor
Old Aug 5, 2009 | 02:01 PM
whammer3024's Avatar
ROTM Winner
tranny mount? bad alignment?
Old Aug 5, 2009 | 02:07 PM
divineal's Avatar
how much is a tranny mount? and could it be alingment?
Old Aug 5, 2009 | 03:02 PM
stock trany mount is about 10 bucks. dont use a poly trans mount they magnify vibrations. if it was alingment u would feel it in the stearing wheel.
Old Aug 5, 2009 | 05:17 PM
divineal's Avatar
no it shakes alot like from the tranny might it be a misfire? or something to do with the ignition system? lower rpms in higher gears is what triggers the violent shaking
