LT1/LT4 Tech 1993-1997
help buld my 94z
Old 08-29-2011 | 10:57 AM
dogdog130's Avatar
yea im looking at those my self so u still have the ac right bec i keep seeing no ac and egr
  #42
Old 08-29-2011 | 11:00 AM
sgtdupree's Avatar
this thing is back firing like crazy. is that jus cuz I'm drivin wit jus headers
  #43
Old 08-29-2011 | 11:13 AM
sgtdupree's Avatar
the shop is sayin its gotta b outta time and it's gonna blow the muffler cuz it's back firing so bad. I ain't know it could b outta time. and I didnt take the opti off.
  #44
Old 08-29-2011 | 01:46 PM
if its misfiring when you let up on the throttle then its probly running rich, if its doing it at throttle up its the opti, crossed wire, bad wire or jumping spark on a wire. maybe a bad valve or mis adjusted rockers if you have worked on it.
  #45
Old 08-29-2011 | 03:02 PM
sgtdupree's Avatar
it's mostly when I let off the throttle did it some when I punched it gettin on the highway. I jus put my headers on. i thought i put the wores back on correctly. if I didn't it wouldn't start? correct? I didn't touch the opti. I have erg blocked off and no u2 sensors. no other work been done. it was runnin fine before
  #46
Old 08-29-2011 | 03:55 PM
without 02 sensors your running way rich, that will explain it. the extra fuel is building up in the exhaust and igniting when you let off the throttle. when theres enough fuel in there it will backfire when at a steady throttle as well.
  #47
Old 08-30-2011 | 05:31 AM
sgtdupree's Avatar
I over heated yesterday comin from the exhaust shop and I had to get towed home. I added fluids and tried to start it this mornin but it won't turn over. any suggestions? how would I know if the block cracked?
  #48
Old 08-30-2011 | 05:38 AM
Psycho's Avatar
I think you can probably check your opti. With the problems you were having prior to the exhaust work and now the no-start. It sure sounds like an opti.
A cracked block could be the worst thing that might happen in an over heat. That alone wouldn't keep it from starting tho. To check for a cracked block or a blown head gasket, a test can performed to check for hydrocarbons or exhaust gasses in the antifreeze.
  #49
Old 08-30-2011 | 09:17 AM
check for coolant in the oil, oil in the coolant. do compression test on all cylinders.
  #50
Old 08-30-2011 | 03:08 PM
sgtdupree's Avatar
motor is blown!!!! i took it to the shop and they said they can smell fumes comin outta the radiator. they said I need a new motor
