LT1/LT4 Tech 1993-1997
Headlights!
Old Feb 16, 2011 | 06:11 PM
Stevenmer3's Avatar
Exclamation Headlights!
One of my bulbs in my 94 z28 just went out so i need to buy a new hallogen and all but are there any aftermarket ones to buy like with the blue leds or is that impossible lol help please
Old Feb 17, 2011 | 05:25 AM
well nothing is impossible. there are a couple threads on here where the headlights were changed to halo. as far as whats available in a plug and go then your outa luck. they do make a little brighter seal beams but thats it. be right back. ok im back, the h4351xv sylvania brights and ek46109 eiko dims are a little brighter. at least supposed to be, im gona try em. you can also do a bulb mod where you take the sealbeam apart and change the light only. i didnt look into that much.
Old Feb 21, 2011 | 09:25 AM
Stevenmer3's Avatar
ok well we tried to replace the headlight this weekend it lasted 5 mins turn the car off went to dinner came back and the light wasnt workig somthing is wrong with the wiring. we tried to replace the fuse but there wasnt a a spot for the fuse like there wass a slot but nothing in it
Old Feb 21, 2011 | 09:38 AM
so only one light is not working? if thats the case then i dont see how it could be a fuse. check for power to the plug at that light. test the light itself. i got into a bad batch of bulbs at the parts store and went through a few in a couple of weeks before i got good bulbs. dang things are not cheap either.
Old Feb 21, 2011 | 09:47 AM
marten's Avatar
you have to remamber if just changing the bulb don't touch the light the oil from your hands can mess it up.
Old Feb 21, 2011 | 10:09 AM
martin i think,,, hope he was talking about the headlight and not the driving lights. you can get blue driving lights.
Old Feb 21, 2011 | 12:28 PM
traumadog's Avatar
If he has a '94, unless he swapped out the quad headlight sealed-beams for bulbs and buckets, then there's no issue with touching the lens...
As for the OP, I'd check on the wiring/socket for the bulb too. If there's dirt/rust in there, it might break the contact enough to keep the bulb off.
Old Feb 21, 2011 | 01:46 PM
marten's Avatar
i just know when i replaced my lights i noticed that you can replace the bulb but the older ones you can't
Old Feb 21, 2011 | 06:01 PM
Stevenmer3's Avatar
we tested the light it self and it worked but i never checked the fuse its self. ill try to clean it off n all but how would i do that
tim dawson
Feb 25, 2019 02:24 PM
Pig Hunter
Dec 7, 2010 10:51 PM
cocanut
Oct 31, 2010 07:37 AM
JordanN
Aug 8, 2010 07:06 AM
Skippysnax
Apr 20, 2008 07:28 PM
