header ?
RE: header ?
ORIGINAL: SpecterGT260
i suppose.... I can put my full fist onto each of my spark plugs and header bolts now that i have the tubes in. the manifolds were a complete biatch though.....
RE: header ?
well all in general you have your good things and bad things about headers. no matter what ,to get your car to perform good that has to be one of the first thing to install. but if it makes it a little bit easier to change spark plugs i will take it. better than manifolds.
RE: header ?
Overall I have good things to say about headers because of the power increase. That said, purchase something that you install once and never have to touch again unless you're taking the heads off. It's fine once they're on, but getting them there is a little tough. Changing the plugs in our cars is always tough and with headers removing the oil filter gets a little sketchy, but overall it's not that bad.
RE: header ?
How many people went ahead and ran dual exhaust when they installed there headers? because I wanted to run headers along with exhaust. but i want to not loose to much for ground clearance because 4th gens dont have much as it is
