header ?
Old Jul 7, 2006 | 02:06 AM
brock417's Avatar
Default header ?
ok i know this is kinda a newbie question but i was wondering what LT and ORY means?
Old Jul 7, 2006 | 01:46 PM
YouLost's Avatar
Default RE: header ?
Im guessing LT = Long Tube, And other one... no idea
Old Jul 7, 2006 | 08:49 PM
SickSickSick's Avatar
ory = off-road y pipe. sick
Old Jul 21, 2006 | 02:21 AM
TimmyTheWop89's Avatar
sick jsut wanted an update hows the drag racing been going for you? got any new times?
Old Jul 21, 2006 | 04:46 PM
what's up timmy? long time no see. times are the same but gained some miles per hour with the 4:11 gears. finally got some slicks and rims. getting them mounted today. ordered two holley 450's for a dual quad setup. trying to get it all back together. they are having a big event the 29th. i hope to be ready. Sick
Old Jul 21, 2006 | 06:26 PM
there u go those slicks will make a world of difference. did you get a different rear end or jsut buy a differential? im trying to decide what route to go for a rear end for myself.
Old Jul 21, 2006 | 09:42 PM
well the first rearend i built had some side to side slack in the carrier. after about 3 runs the mini spool twisted sideways in the carrier and bent the pinion rod. i had to cut a hole in the housing to get the pinion back out and rescue my gears. i had an extra carrier and housing so i ground down the warped *** mini spool the best i could where the locker pieces fit back between the axle spools and built the rearend again. this ones tighter than ****s hat band. i'm convinced that slack was from the carrier being just plain wore out. as long as your carrier is in good shape and you don't mind having a locked rearend, the mini spool is the cheapest way to go. other than welding the spider gears. since yours is a street machine a locked rearend might not be the best choice. just from the few times i've drove mine you can tell it puts alot of stress on the axles when making turns. if your in the market for a good used posi-unit i know of an ebay seller that has a good rep for selling rearends. heres a link to some of his parts and his email address ... http://motors.search.ebay.com/_W0QQsassZdansgears ... junkmasta@aol.com ... talk at ya later. sick
luvmysccamaro
Mar 28, 2009 06:23 AM
stock86
Dec 16, 2008 11:43 PM
chevyfreak
Dec 13, 2008 12:27 PM
blainemyers
Aug 21, 2006 11:17 PM
MadMikeZ28
Aug 5, 2006 06:12 PM
