LT1/LT4 Tech 1993-1997
harmonic dampener
Old Aug 9, 2009 | 02:15 PM
carguylt1's Avatar
Default harmonic dampener
When I took the dampener off my 95Z there wasn't a half moon key on the crank snout did they not put them on the LT1 or has mine just disappeared?
Old Aug 9, 2009 | 03:15 PM
Lt1's don't use or need one. Just stick the dampener back, does not matter how it is pointed unless you are one of the unlucky ones that has an engine that needed touch up balancing to meet factory specs. Make sure the retaining bolt is torqued to spec. If you intend to drive something big off the crank snout, such as a blower, then you should go for a key.
Old Aug 9, 2009 | 10:25 PM
if its like a 93 there should be an arrow on the harmonic dampener/balancer. the arrow is pointed straight up when number one cylinder is tdc.
1976camaro
70-81 V8 Tech
Dec 14, 2010 12:28 AM
VCA
Nov 4, 2010 10:04 PM
jarrod1875
LS Series Tech
Oct 29, 2009 12:45 PM
camie
67-69 V8 Tech
Mar 16, 2008 12:28 PM
383Z28
Apr 14, 2006 12:42 AM
