LT1/LT4 Tech 1993-1997
granatelli maf sensor
Old Jun 3, 2009 | 02:55 PM
Trevik z28's Avatar
Default granatelli maf sensor
I read about nitrous and how importent it is that computer isn't tuned, because it isn't right ignition, so i wonder how granatelli maf works with nitrous! I belive that the maf adjust the ignition???
Thanks!
http://www.garaget.org/?car=89384
Old Jun 3, 2009 | 08:31 PM
maf provides info for the computer to use. the ecm or ecu controls everything using the info it gets from all the sensors.
Old Jun 4, 2009 | 03:14 AM
Trevik z28's Avatar
So you mean it works good with this granatelli sensor?
Thanks
Old Jun 4, 2009 | 09:18 AM
now i dont know that much about boost with nos i just know the computer controls the ignition using info from the maf. so if u need anything changed i would think it would be the ecu. or add on chip.
Old Jun 4, 2009 | 12:40 PM
95slvrZ28's Avatar
Don't buy a new MAF, it's not worth your money. If you're planning on running nitrous the stock MAF is going to work fine, you're going to want to get the PCM tuned. Changing the MAF isn't going to change the tune.
Old Jun 4, 2009 | 01:13 PM
Trevik z28's Avatar
ok.. I have a granatelli maf sensor mount now! But would it works with nitrous???
Old Jun 4, 2009 | 03:30 PM
95slvrZ28's Avatar
Yes it will work with nitrous, but you're still going to need to tune for the nitrous regardless of the manufacture of your MAF.
Old Jun 6, 2009 | 02:31 PM
Mr_Exacto's Avatar
Default The MAF Debate - Did the Granatelli MAF help?
If you don’t mind, please post your thoughts on the Granatelli MAF. I’m curious to see what you think.
The stock MAF vs. performance MAF vs. de-screened stock MAF debate appears to have been going on for a while. I cannot personally account for which is the best way to go, but there is some controversy on the subject. The pro-stock MAF believers tend to argue that the screen in the stock MAF allows for a more accurate reading and thus, a more precise fuel/air ratio. One guy compared how the screen properly aligns the air in a stock MAF to how the screen in a kitchen faucet aligns the water flow. I have also read that some people claim to have lost performance and experienced difficulty tuning Granatelli MAFs. Once again, I do not know which MAF is the best and cannot personally account for one particular kind, but would like to hear what you have to say.
Here are some links concerning the MAF debate:
What kind of MAF is the best debate:
http://www.ls1tech.com/forums/lt1-lt4-modifications/287430-granatelli-vs-maf-ends-vs-descreened-stock-vs-bone-stock.html
Why MAF screens are important:
http://www.gmtips.com/3rd-degree/dox/tips/maf/maf-screen.htm
sk8rax350
LS Series Tech
Jun 27, 2011 01:01 PM
xXChipXx
May 21, 2011 10:47 AM
fuhhuayt
May 5, 2011 01:04 PM
EagleRex
Jul 20, 2010 03:36 PM
reaper2702
Sep 10, 2009 08:15 PM
