LT1/LT4 Tech 1993-1997
gears?
Old Jan 21, 2007 | 01:20 AM
jswizzle123's Avatar
Default gears?
lookin to replace my stock gears to gain some low end power , what would you suggest ? and how hard is it to replace gears?
Old Jan 21, 2007 | 04:22 AM
95slvrZ28's Avatar
Default RE: gears?
What do you mean by "gears"? Are you refering to purchasing new gears to go into your transmission so you can adjust the gear ratio's there, or are you refering to the final gear in the differental?
Old Jan 21, 2007 | 03:07 PM
Default RE: gears?
not really sure, i was just lookin to add a lil low end power and i here changing my stock gears will help that?
Old Jan 21, 2007 | 05:30 PM
95slvrZ28's Avatar
Default RE: gears?
Well, you really don't get more "power" but by changing the gears in the differental to 3:73's or 4:10's you can get your revs up faster, and make a better 1/4 mile time, providing you can get traction.
Old Jan 22, 2007 | 08:09 PM
Gentleman Jack's Avatar
Default RE: gears?
ORIGINAL: jswizzle123
if you're asking this, you don't need to be doing it yourself. changing them is easy (with proper tools and a little mechanical inclination). setting them up properly is the hard part. if you have someone else do it for you (i.e. a shop), be careful you don't go too low gear on an otherwise stock car.
Old Jan 22, 2007 | 10:15 PM
Default RE: gears?
If it isa street car 3.75 for auto or 4.11 for 6 speed. Anything over that can get annoyng after a while and really kills the fuel mileage.
sepadowd
Aug 4, 2011 07:59 PM
91camaro350
82-92 V8 Tech
Aug 5, 2010 10:28 AM
gfrench
Jun 19, 2010 10:16 PM
1bad96Z28
Jun 9, 2007 09:12 AM
