LT1/LT4 Tech 1993-1997
Full exhaust swap?
Old Feb 29, 2012 | 08:32 AM
  #21
MKCoconuts's Avatar
As far as air/egr go, you lose some weight (like 7-8lbs) and the engine bay looks much cleaner without those ugly pipes running behind it.
Correct. Race headers will fit all years. I also would suggest going from the bottom if you can when doing these.
Darn, I was beat out.
Old Feb 29, 2012 | 08:36 AM
  #22
BudBrown's Avatar
November 2011 ROTM
Ride of the Month Director
i still saw it... im pretty sure i just wanna drop the k member...
thanks for the tips.
Old Feb 29, 2012 | 08:58 AM
  #23
MKCoconuts's Avatar
Sweet. Gives me that warm, fuzzy feeling again. Haha.
Oh I see. Take the really easy way out! Guess that'd be a good idea though. Give you a chance to clean the engine up real nice and see if any other problems presented itself.
Old Feb 29, 2012 | 09:29 AM
  #24
BudBrown's Avatar
November 2011 ROTM
water pump, timing, opti, plugs, wires, throttle body (clean up), and headers.
Im also doing the LED lights, HID headlight upgrade, stubby antenna, new door seals, and anything else I can get away with. I want it to look stock and be completely different.
Tax refund... lol
Old Feb 29, 2012 | 11:03 AM
  #25
Catmaigne's Avatar
The Pacesetter engineers didn't measure correctly when placing the outlet for the EGR pipe. It sits pretty far from the intake manifold and the EGR pipe tears easily when stretched to fit the gap. I eventually removed the whole system because it was filled with leaks.
Old Feb 29, 2012 | 03:30 PM
  #26
BudBrown's Avatar
November 2011 ROTM
huh... is there a way to extend the pipe?
Old Mar 1, 2012 | 10:59 AM
  #27
BudBrown's Avatar
November 2011 ROTM
anyone? I want to have this ironed out when the $$ gets here.
Old Mar 1, 2012 | 11:03 AM
  #28
MKCoconuts's Avatar
I don't think any one knows...
I think most of us just rid ourselves of it when we did the install.
Old Mar 1, 2012 | 11:58 AM
  #29
BudBrown's Avatar
November 2011 ROTM
hmmm... ok what is the pro/cons of the delete?
Old Mar 2, 2012 | 08:12 AM
  #30
MKCoconuts's Avatar
In my opinion, you can't really decide based off a pro/con. It mostly depends where you live that it may/may not become an issue. Technically speaking, it is against federal law to remove any type of emissions unless the vehicle is for off road use only. But the federal government has better things to do than go around and check every one's vehicle.
As far as pros/cons, it looks cleaner without it there. That's about it. Haha.
