fuel injectors 94 z28
i have a 94 z28 with 102000. the car is basically stock, it now needs fuel injectors and posibly a fuel pump. what is the stock injector size, i think they a 24 pound but not sure, and what is a good brand to buy, also what is a good fuel pump?
look around your area for an injector shop. i use a place called doctor injector. they can clean and flow test em for cheap. then if ones bad they will have some or can get them overnight. it is best to change injectors as a set. not a must do thing its just best to. stock is 24.
